Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2504 Questions View all
Capacitor replacing on iPhone 5
Hello.
I've replaced the "Audio Control and Power Button Cable", thank you very much for the step-by-step.
As I almost finished, my screwdriver slipped and I've removed a couple of capacitors (I think that's what they are).
Here is a picture, it's right next to the battery connector:
Can someone help me to identify so I can (hopefully) re-solder them?
Thank you.
Peter.
Update
Hello oldturkey03.
I'm just trying to see if these are the parts needed:
The manufacture codes are C0402C0G1C560J020BC for C279 and MMZ0402S121C for the FL11.
Thank you.
Peter.
Score 1
Add a comment
Chosen Solution
Peter, that is reference designator FL11 is a 120ohm 210mA inductor in a 01005 package and
reference designator C279 is a 56PF 16V 5% capacitor in a 01005 package. Hope this helps, good luck.
Score 5
6 Comments:
Hi oldturkey03. Thank you for the info. I'm trying to get the parts. £0.18 for a part and £12 delivery :(
by
Hello oldturkey03.
Thank you.
Peter.
by
Hi guys! where you buy this parts? please help me crushedrepepper@gmail.com
by
CRUSHED RED PEPPER, they are available at digikey.com
by
What does this look like on the iPhone 6?
by
Show 1 more comment
Add a comment
FL 11 is required and will have to get back in place for the phone to work. Honk if you need microsoldering assistance.
jessa
Score 4
3 Comments:
Hi jessabethany. Thank you for the comment and support :)
I will probably need some assistance as soon as I get the parts.
by
Hi Jessa,
can you confirm me, that there are "unnecessary" parts in this section?
I ask because I ripped off 2 parts there, but the phone is working. Cant see any bug so far.
Maybe I ripped of 2 capacitors, that was used to smooth voltage-fluctuations, as I remember they are often near to power-supplys.
greetz revnu
EDIT: even if my assumption is right, what type of long term-effect I can expect bye missing smoothing-caps?
by
Have the FL11 and C270 pry damage on a 5C. What you will encounter is
- Battery gas gauge is incorrect
- Cellular call radio lose like 5-10dB signal strength
by
Add a comment
wow! you guys rock….
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 15,341
