Why can I not find the Airport network?
The Airport Extreme is on but when I try to connect, I can't find the network.
i think you should reset the apple airport.and launch the apple utilities once again .so lets go and setup the airport once again . setup your user name and password and lets connect your all devices .for more information contact Apple airport support and i hope this would fix issue ..thanks
If you are unable to find the wireless network, you can try a few different things. If your router is far away from the device you're trying to connect to the internet with, you may need to move the router. It should be away from walls or metal surfaces as well as devices that may cause interference such as microwaves or wireless phones. If this option doesn't work, you might need to install more routers or signal extenders to ensure that the Wi-Fi signal reaches across your house.
The problem could also be an internal hardware failure in the router. You may need to replace the antenna or the Wi-Fi card. There is additional information listed in the troubleshooting page.
See if any of the following articles can help:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,840
