2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Trackpad replacement from MB Pro 15'' Unibody Mid 2012
Hi,
Can I use a trackpad from Macbook Pro 15 Unibody Mid 2012 to replace on Macbook Pro 15 Retina Display Mid 2012?
Update
Thanks for answer. However, I was able to check catalog compatibility before I asked the question.
What I'm wondering is that anyone tried to fit that trackpad from unibody Macbook Pro to Retina Macbook Pro?
Question is asked because there is no compatible trackpad in catalog itself, it comes only with top case(retina compatible) and massive price tag.
Since they both look the same (or almost the same), I'm asking if anyone tried and can confirm it works, if that explains better my intentions.
Score -1
Add a comment
1 Answer
Catalog says NO
You might get faster/more accurate results to contact iFixit customer service directly using the link below.
This is the volunteer DIY help forum. We are not affiliated with iFixit directly in any way.
If this answer is acceptable please remember to return and mark it.
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749. Image
Product
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
$43.99
1 Comment:
Not even remotely close in any way.
by
Add a comment
Add your answer
Michal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 239
