4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Questions View all
iPod will not turn on?
I was using the iPod Touch (16GB, no camera) when it suddenly turned off and would not turn back on. Tried charging it for several hours and no change, it still won't turn on. Could it be the battery needs replacing? Seems the logical place to start but wasn't sure?
Score 7
Add a comment
Most Helpful Answer
Try the easiest first....try cleaning out the dock connector with some canned air to see if there's anything keeping a good connection from being made. If that doesn't work, open it up and see if anything has come loose/broken etc.
Score 2
Add a comment
Have you tried plugging it into the computer to see if it registers? If it gives you an error, maybe google the error to see the meaning. Just a thought
Score 1
1 Comment:
i have the same problem with mine. t does not register when i plug it into the computer, also the home button did not work prior to this. Help?
by
Add a comment
was there a solution? if so please list what it was. Thank You!
Add a comment
mine dosnt reg wen plug into laptop either
Add a comment
Long time since this was posted, but I had a similar problem. iPod would not turn on, nor take a charge.
I was able to fix it by plugging it into a power source then pressing the home and power button and holding both for about 30 seconds. The Apple logo popped up and it would now take a charge and power on.
Add a comment
How do you restore iPod when it’s locked showing USB to iTunes and says can’t restore, no network
Add a comment
Add your answer
Kelly P will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,561
