A professional extra burner. Released in 2008, with model name SB30.
3 Questions View all
Is it acceptable to use large pots or pans?
I am unsure if it would be safe to use pots and pans larger than the heated surface area.
I've done so on a conventional home oven, but I am worried if this hot plate can even handle the bigger loads.
Score -1
Add a comment
Most Helpful Answer
It won't hurt anything, but it could be not safe as the possibility of the pan/pot spilling over.
The other factor is the transfer of heat will give you a hot area unless your pan/pot is clad with a Copper or Aluminum core to smooth out the hot spot.
You will also need to think about the volume you are heating here. Boiling a large pot of water will take longer and it may not be able to sustain (recover) the boil. Review the BTU's of the heat plate.
Score 1
Add a comment
No, you must only use pots etc, that fit the actual burner, otherwise the food will not cook evenly.
Add a comment
Add your answer
kevin phan will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 18
All Time: 173
