A point and shoot camera in the Cyber-shot series, released in 2010.
9 Questions View all
cybershot dsc-w310 is showing only white screen
it is showing a white screen when it is turning on
and no change for further
Score 3
7 Comments
any answer for this? I also got white screen everytime i turn on the cam.
by
Push down all the buttons at once and push and hold the on -off button until it resets and the white screen should disappear .
It took me a few times,as it's a bit awkward.
by
I get a white screen when I take a picture, almost everytime, the odd time it doesn't?
by
I see the image fine through the screen but when I take a picture, it comes across as almost all white (slight horizontal shading).
How does the reset work? Which buttons should be held down? all of the menu and display buttons on the back?
by
If the almost white screen (we call wash out) only happens for pictures then the issue is your lens or settings. Go to main menu/settings/initialize settings. If that doesn't work then you will need a lens replacement because you have a bad iris/aperture.
Question are the lines slightly bent? Do you have any heavy hues like purplish.. etc.. in your picture or is it just washed out?
by
Show 2 more comments
Add a comment
1 Answer
Most Helpful Answer
Sounds like either moisture damage, a loose or bad lcd or bad board. If you are up to it open up the unit and
reseat the LCD back into the ziff clamp and see if that helps. There is a clamp that holds the LCD down and
it may have come loose. Try to reseat the LCD, and while you have the LCD disengaged examine the flex
cable for damage. Keep us posted. If you need a disassembly guide just let me know.
Score 2
1 Comment:
How do you know how to open the camera?
by
Add a comment
Add your answer
praveen will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 20
All Time: 5,397
