2.26 or 2.4 GHz / White plastic unibody enclosure
Logic board fuse blown
Hello i think i must have blown that fuse those two screws is there a way to fix it
Score -1
Add a comment
1 Answer
Chosen Solution
Mtaka, that is a Diode. It is a RCLAMP2402B diode and can most likely be replaced. If you have never soldered an SMD device, you could just replace the MagSafe DC in board. runs around $10 to $15USD board
Score 1
1 Comment:
...and many pins seems to be damaged on the LVDS socket. Could you post a close up pict of this socket and the LVDS cable connector end ?
by
Add a comment
Add your answer
Mtaka will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 439
