The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
One M7 cannot pass bootloader with replacement display
Hi everyone,
I habe a weird problem with my M7.
It has broken frontglas, but the lcd an touch are working well. Now I wanted to give it to my father as present, but with a fixed glas.
I ordered a replacement part (fronthousing + display + touch).
When I connect the display (just the flexcable next to the battery flex) the device turn on, but after displaying the bootloader image the screen turns black, but the backlight keeps shining.
When I try to enter the bootloader menu it works without any problem. I can navigate there and fastboot works fine.
When I try to boot into recovery mode the screen stops changeing displaying the "entering recovery" screen.
I also waited for some minutes... nothing happened.
When I reconnect the original display, everything works fine again.
First I thought that the replacement part was broken so I sent it back and bought a new one from another seller, but the same thing is happening again.
I already tried flashing different roms and recoverys ( newst HTC Stock and newest CM 11; CWM and TWRP), but that made no difference.
Does somebody have any idea?
You think it would be worth investing in sunshine s-off and trying different hboot versions or turning it into the google play version?
Thank you :)
2 Comments:
Solved it yesterday evening. Somehow it really was related to the kernel. After flashing a 5.0.1 kernel it worked, but not with an kernel older than this. Very weird.
by
Hello Justus
My M7 also has a new screen and boots with problems. The software is not compromised. If i look in the Software-information page in the settings:
Android-version: 5.02 / HTC-Sense: 6.0 / Software: 7.19.401.51 / API: 6.55
Kernel-version: 3.4.10-g5ec-762d
Did you have to unlock the HTC to upgrade the kernel?
Do you still have the files needed for flashing?
Best regards
Matthijs (NL)
by
Add a comment
1 Answer
Hello,
It's very difficult to localise the problem.
Firstly, we must unplug the battery.
I you unmount cables and screws hardware before unglugging the battery, I think the main board is faulty.
have you verified evry connector ? every cable is correctly plugged ?
Best Regards
Add a comment
Add your answer
Justus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 436
