Microsoft's third-generation Xbox game console, released November 22, 2013.
730 Questions View all
Why my cover for my xbox one not going back on?
I had to remove my cover to get to my fan to remove a chain after doing the hard part I can't do the easy part of putting cover back on Xbox. Is there a trick to putting it on because I don't seem to get?
Score 4
4 Comments
I removed my front plate on my Xbox as I went to put it back on it won’t fit in and is bashing against the bumpers
by
I'm about to throw this thing through my wall it's so hard to get back on its extremely frustrating I would pay someone 5 bitcoins to get on for me!!!
by
The cover of my Xbox one when I try to clean the fans will not click back together what should I do
by
I can not for the life of me get this back on but i dont want to try the method of taking off the panel in the front. Or is that required to put it back on because no matter how i try to clip.it in it doesnt work. I line up the clips on the front and place them in but then the cover isnt in line with the stuff in the back and i cant bend it to place i feel like ill snap the panel. Someone please help in anyway if you can. Thank you!!
by
Add a comment
Most Helpful Answer
Yes, there is a trick to it. The trick for me is to explain it!
When I re install the covers on these I put the front of the cover in and make sure it all aligns and I keep my hand on the front of the console while I do the next step.
The next thing to do is to put the console up on it's side with the on/off button up in the air. If you look in the corner closest to the on/off button you will see a pretty long plastic piece that has to go into a slot in the side of the case. At first it will seem almost impossible to get that into the slot while keeping the front of the case aligned, but it can be done. You have to flex the case quite a bit and pull back on it to get that plastic piece into the slot while keeping the front of the console aligned and inserted into it's slots but it can be done and this is the easiest way that I have found to do it.
I hope this helps. It's hard to explain, but I hope it makes sense.
Score 11
14 Comments:
lol you directions where all i needed, like 10 min after i read this i was able to put it back togeather after struggling for hours, but my eject button doesnt work XD the ribbon cable is plugged in.... RIP its cool all my games are digital and xbox one has a manual eject anyway
by
I'm glad that helped! The ribbon cable is probably just damaged. If you ever want it fixed I can fix it. But if it works as is then just go with it!
by
Glad to hear that my answer helped!
by
So do you fix games that are water damage i sent it to Microsoft but the sent it back to me what can i do i know water only got one the RF module
by
We can certainly take a look at it for you. While there is no way to guarantee that we can fix it without seeing it, if the only problem is the WiFi card that shouldn't be a problem at all.
by
Show 9 more comments
Add a comment
For future reference, it's much better for the device, and easier for the person putting it back together to just separate the front panel from the top half of the case. Get the top half snapped into place, then connect the ribbon cable and snap the front panel on, then replace the slide lock and side panel.
Score 3
3 Comments:
Much easier! Thank you!
by
+thanks much easier, until you pointed out this fact I was on the edge of consigning it to the tender mercy of newton.
by
Holy $@$* thank you. I was really about to throw this mf
by
Add a comment
Use duct tape to hold the top in place then wiggle it in really hard.
Add a comment
Ok after reading the best explanation so far I took the front apart from the top and put it on first then peeled it back just a bit then put the top on flat then just slid the front notches into tops and bam
Add a comment
TAKE OFF THE FRONT PANEL. it's removable. Put the front panel on last. Makes process extremely easy.
Add a comment
Add your answer
colemanscott2083 will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 151
All Time: 40,624
