A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
182 Questions View all
Best glue for attaching screen to phone?
My friend gave me his wife's old g2 that she dropped and shattered the digitizer. I bought a brand new pre assembled lcd/digitizer so all I'd have to do is use some 2mm tape and press it in to place. I'm now having an issue where from about the middle on the phone to the bottom is lifting around the edges. I thought I might have done a poor job with the tape so I went in and re did it 2 times now and still the same results. I'm wondering since the factory screen had this black glue like substance holding the screen in what can I use to mimic that and the results. I've read super glue was a bad idea because it gets between the LCD and digitizer. I also saw some one suggested gorilla glue epoxy (the 3300 psi stuff) I'm not worried with replacing the assembaly again in the event I drop my phone before I get a case. I'll just get the frame with the screen. Thanks in advance.
Score 1
Add a comment
Chosen Solution
There is an adhesive called 'Red Tape' that is very, very good adhesive. We swear by it for any and all adhesive jobs we run into. Just make sure that you get everything right the first time, because separating Red Tape can be a real pain.
Score 1
1 Comment:
The problem being is that double sided tape can be too thick for todays phones, hence why the OP is saying that it is lifting.
by
Add a comment
B7000 or E8000 glue. Apply a thin bead around the frame and fit the screen. Hold the screen in place with either tape or elastic bands while it sets. Ideally leave 24 hours to fully set.
Score 1
Add a comment
Add your answer
Jakob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 35
All Time: 3,000
