PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
390 Questions View all
My left analog stick is not moving properly...?
So, I bought this controller about a year ago and, as it was my 2nd controller, never used it so often. Then, my first controller broke, and I had to use this 2nd one since then. So, I noticed that whenever I moved the analog stick to the right, it computed as if I was moving diagonally to the bottom-right corner. Whenever I moved to the left, the movement in-game was as if I was moving diagonally to the top-left.
Then I tried to fix it by opening it and seeing if there's any problem, and it didnt seem like it had. The only thing I did when I opened the controller is that I took the analog stick out and put it back again. Then, another problem appeared: whenever I moved the analog stick upwards, to move forward in-game, it stopped moving after a while, like 5-10 seconds. What should I do? Is that a chipset problem? Please help!
Score 11
3 Comments
I'm having the exact same problem. Can't play fifa properly. I even tried to exchange the left stick with the right, but that didn't help. Can someone help please. Thank you.
by
I'm having the exact same problems, except it's one controller with an analog stick that seems to register all the way up as only about 75% up, despite the neutral position of the stick still appearing to register as the default neutral sitting point. Another controller has the exact same right = down+right issue as you.
I've gone on some pretty lengthy internet safaris looking for a solution to this issue, with no success
by
do yall use control freeks this has happened to 2 of my controllers now and ive use knotrol freeks on both of them
by
Add a comment
Most Helpful Answer
I had a number of difficulties with left thumbstick registering incorrectly, and I found that the following steps helped immensely:
Rotate the stick around a bunch
CLICK the stick down and while holding it down, rotate again
Keeping the stick clicked in, move it downward and blow air into the gap at the top
Put the stick upward and blow into the bottom area
Rotate the stick again, both unpressed and pressed
Blow air all around the inside with the stick clicked down
Release the stick and give the controller a few firm whacks
Click the stick back in and blow around the edges again
Reset the controller using the reset pinhole button for good measure, and then test after reconnecting to the PS4. All my problems seemed to be caused by dirt creeping in while I was sprinting in some game, holding the stick down and forward. Merely blowing some air in didn’t help, the constant agitation and blowing and repeating seemed to be the only thing to clean it out without opening the device (which is a fair degree harder than i anticipated when I attempted it)
Score 28
18 Comments:
Wow, thanks so much, i bought a new controller months ago because it was having this problem but i had a friend come over today so i tried to look online for a fix and this helped. Thanks!
by
Wow! Thanks so much too! Many patries were ruined by this controler but now it's FIXED!
-written by a 19 year old
by
Dude youre a genius i tried it and it instantly worked i thought i would have to go repair it and pay money when i could've just fixed for free thank you so much
by
OMG! You are amazing! My controller was with this issue and now it's perfect, thanks to you!
by
Yo this worked for my Xbox controller thank you so much I got scared cause it’s a custom controller with my gtag engraved in it I honestly can’t thank you enough
by
Show 13 more comments
Add a comment
I had some similar problems. I teared down the controller and cleaned all part really good with electrical spray ment for cleaning stuff like that. Waited for it to dry properly. It worked just like it was brand new. Try it. The spray is not expencive.
Score 1
5 Comments:
Cheers! Must give this a try.
by
A.....im finna bring my controller back rite on all y'all 4 having this problem first..if dont work ill buy a new controller change tha gud parts and return it..&&^& sony as much money as i paided they should fix 4 free WHAT Y'ALL THINK ABOUT THAT
by
Your comment makes my brain bleed.
by
are you drunk?
by
Brother… you are the absolute best
by
Add a comment
ty to Nick Hughes  man im suprised that worked thank you very much
Score 1
Add a comment
I have a similar problem everytime I try to move straight my character moves slightly to the left. And it makes it really hard to play any games.
Add a comment
The old analog stick needs to be de-soldered and removed and a new analog stick needs to be soldered on. If this does not correct the issue, then the conductive film needs to be replaced. The conductive film is the thin plastic film that the ps4’s d-pad and other buttons make contact with in order to register they are being pressed. Sometimes the film malfunctions and causes the controller to act in erratic ways that don’t actually make any sense. This was similar to the way the PS3’s controller would act erratic when there was not enough contact being made between the film and the contact points on the controller.
1 Comment:
This is my problem but its not making contact because the part that rotates when you press the l3 or r3 button has a third of it broken off and when i opened the controller there was no broken piece in their , because its broken i have to push down harder to get enough contact for it to work. ( i want to know what the pieve that rotates is called so i can buy a new or if you can evan buy them.
by
Add a comment
I have got a Xbox controller brand new last month on may the 5th and my I pushy my anolouge stick down it feels like I’m going. Over a bump and I don’t kno what to do
1 Comment:
Get you a ps4/5 lol.
by
Add a comment
There are potentiometers on the controller that need to either be replaced or cleaned. Without a magnifying glass, it’s better to just replace the potentiometers.
Add a comment
If cleaning and calibration don't work, you may need to replace the analog stick. You can purchase replacement analog sticks online or at electronics stores. Just be sure to get one that is compatible with your controller.
If the issue persists after trying the above steps, it may be a more serious hardware problem. In that case, you may need to take your controller to a professional repair shop or contact the manufacturer for assistance.
Hope these will be helpful for you
Thanks
Acacia wood
Add a comment
Add your answer
Drable will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 153
Past 30 Days: 625
All Time: 127,465
