The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Screen moving up and down randomly...shaking?
Hi I've had a nexus 5 device for almost an year...no issues..then a few days ago my screen started shifting up and down at will...I might have dropped it but if at all it was no more than 2..3 feet..this happens on any app..even home screen...like the screen gets wrapped around and the top part shifts up and comes back up from below...js keeps shaking...i can type perfectly if only i can click at the right place...neither the glass nor the image appears broken...stock software...help!
Score 27
13 Comments
I have the same issue it even happen in recovery mode too, definitely hardware issue
by
Did you check: https://www.youtube.com/watch?v=4pks4idq...
Looks like flex cable issue. I haven't tried it yet.
by
How can I fix it
by
why was my screen goig up and down a few minutes ago. What is going on. Fixit.
by
I purchased Nexus 5 LG from Amazon in 2014. Since last week, the screen has started flickering and shaking. I believe I made a mistake. I got excited after experiencing Nexus 4 Samsung. Google should have continued with Samsung, but not LG. Any help is welcome. Cheers. (N. L. Vijaykumar, Brazil)
by
Show 8 more comments
Add a comment
Most Helpful Answer
I fixed this problem by replacing the daughter board(Check step 8 on the ifixit article: Nexus 5 teardown) that contains Micro-USB port, Microphone, Notification LED, etc. Nexus 5 definitely has a major hardware flaw.
Score 2
Add a comment
I faced the same problem on my Nexus 5 recently (after more than 2 years of usage). I was able to fix this problem by opening the back panel and pressing the flex cable (which might have gone loose) on connection areas.
In some cases the flex cable might have got damaged resulting in this issue. If that's the case with your phone (i.e. if even after the above procedure, the flickering persists), you can try replacing the Flex Cable. Check "https://www.youtube.com/watch?v=4pks4idq... for flex cable replacement.
Score 1
Add a comment
Old thread but for anyone in the future asking this, I had the same problem and replaced the charging port. There's a good YouTube tutorial here and I found the part on Newegg here. I bought from that seller and had no issues. The replacement itself is pretty easy and it seemed to fix the problem.
Score 1
Add a comment
hi everyone had the same issue few weeks back. i browsed regarding this problem. most of them said it was solved with changing the flex cable. i was then in vizag. showed it in lg service centre. they said we have to change the display. went to another shop he to said the same. i was not convinced. later i showed to in hyderabad at lg service centre again. i was ready to change the display. i just told him what i read in internet. to my shock he just changed the flex cable and issue was resolved. i just felt both guys in vizag wanted to make money. felt it is my responsibility to share this with u all. CHANGE THE FLEX CABLE.
Score 1
2 Comments:
Sir what was the coast of changing it in lg centre
by
What is the cost of the flex cable
by
Add a comment
i had the same probleme with my phone and i do this
https://www.youtube.com/watch?v=Af5DvIZw...
it work for screen too, it's the same cable.
i even try to change the daughter board but this look like a motherboard connecteur problem.
2 Comments:
Wait.. This is a permanent fix for the screen shaking\flickerng? Please respond because I need a permanent fix.
by
I have this problem of the screen moving up & down on all the programs I go into also.
by
Add a comment
Replace the PCB board that contains the Micro-USB port (the one at the bottom).
Search for the following.
LG Nexus 5 USB port flex cable complete assembly.
Make sure you get a complete assemble (which includes the black plastic) otherwise its a tough job transferring the double sided tape.
Add a comment
I found a way to enhance connection of the flex cable: solder flux pen (no-clean), brushed on the connector, it works fine.
Add a comment
I experienced this on my iPhone just 1 hour ago, the problem only exists when power cable is connected and charging.
If disconnected from powersource, everything is smooth again.
The comment of Prashanth above is correct, something related to USB charging port. Maybe the smartphone was presssed hard on your pocket or was dropped which caused the problem.
Add a comment
my phone was scrolling up and down by itself.How do I stop it?
Add a comment
Add your answer
dev will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 99
All Time: 63,314
