AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
Source for replacement MagSafe cable
I've looked at the reviews for replacent MagSafe cables for my MacBook charger on eBay and Amazon and they are really dismal. Is there a source for QUALITY replacement cables? I'd like to do a repair that will last at least as long as the original.
Score 4
Add a comment
Most Helpful Answer
Here's the guide for doing it along with a parts source:
MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement
Score 3
1 Comment:
I managed to completely destroy one Mac charger trying to replace that cable. But I did salvage the new cable. My plan is to next time split the charger body apart, cut the damaged cable just inside of its strain relief. Then install heat shrink to the two wires, solder the new cable to those, and then reassemble the charger case and "wings". This way I won't have to remove the charger from the bottom half of the shell or mess with the charger circuit board at all. I really think this is the way to go.
by
Add a comment
Sadly, Apple doesn't offer replacement parts for the AC adapter.
They look at it as a safety issues between what it takes to open the welded case and the possibility of damaging the computer.
Score 2
Add a comment
Add your answer
John Lewis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,978
