Any tips for replacing the charging port?
I want to replace the charging port as it is broken. Please help.
Please check out the touch screen replacement manual as far as the usb ribbon is changed.
You may change it without the motherboard remove Step. So from Step 5 go directly to Step 9... It is easy.
You will find replacement part on aliexpress site.
Hi I have the exact same problem where is this manual you are referring to? Could be kind enough to post me a link? Cheers
Thank you! It worked perfectly.
Hi I have same problem
I was ordered this part 2 time from eBay but after replacing it.
No service
There is reception problem please guide me from which place original part will available
Hi Guarav Narang Sir
Please help me about replacing this part
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 8,422
4 Comments
Hi Gaurav, I just want to ask, when you replaced the charging dock where there any components on it that you had to solder? Or was it a simple screw/unscrew replacement.
Thanks a lot!
by Etien
Just un screw and replace a riblon that is gently glued
by Marcel Robert
Hi Marcel, thank you so much for your assistance. One last question I promise and forgive my ignorance in the topic. Regarding the Xiomi mi3 charging docks, it seems that there are two options.
1)One with a mic on it (http://www.aliexpress.com/snapshot/68262...)
2)One without (http://www.ebay.com/itm/231518898672)
Not sure which I needed I ended up ordering both. Is the mic soldered? Which one should I use?
by Etien
I want replace charging pot.I need open whole phone?
by gsajnala751
