1.83, 2, or 2.16 GHz Core Duo processor
268 Questions View all
Why does screen flicker on then go black?
On my Macbook Pro A1150, screen suddenly went blank / black. Power off and on, and the screen flickers on, then goes blank. Otherwise, powers up successfully. What do I need to replace or fix? How?
Update
OK, it took me six days to find an external monitor. I had tried on my flat-panel TV, but received error, "invalid format." Now, on an old flat-panel Dell monitor, two part answer, but bottom line is, external screen SEEMS TO WORK. However, in Mac mode, comes up obviously in wrong video mode and no way (none apparent to me) to adjust that. In Windows mode (Boot Camp), Windows XP comes up can read screen fine, then switches and error says "cannot read this mode" (paraphrase, forget the quote).
So, two questions now. 1) Must be my problem is NOT the logic board, so is it more likely the Mac laptop screen, or that "converter" card? 2) Maybe I just use an external monitor, but how do I change video modes when can't get it to come all the way up to place where can change? Thanks for advice.
Score 2
Add a comment
1 Answer
Chosen Solution
First hook it up to an external monitor to isolate the problem. Please tell us what happens. If it works then we can look at the display data cable, the inverter board and lastly the LCD.
Score 6
4 Comments:
+ Good preliminary troubleshooting steps
by
+ Ralph
by
Your update is hard for me to understand, I'm not sure what you're talking about with the "mode" thing. What is important is that you got a picture. This narrows the problem down to one, or a combination of three things: the Display Data Cable, the inverter board or the LCD. In order of cost, I would go for the cable first,then the inverter and then the LCD.
by
Add a comment
Add your answer
Chuck will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 11,068
