Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Question Closed
How to remove iPhone display assembly
After replacing a friend's iPhone screen, I found that I needed to reseat some display cables, but I couldn't get the new display back open. My suction cup would come off before the display would budge. Does anyone know another way?
Add a comment
1 Answer
Most Helpful Answer
At the Headphone Jack corner, just above the Headphone Jack port, the front screen frame has a very thin area which can accommodate a thin pry tool. The tip of a razor blade could be used. Carefully insert the tip down between the iPhone frame and the screen frame about half a mm, and pry up the screen. Be careful not to damage either frame. Look at an old screen to see this area.
Score 1
1 Comment:
Thanks! I tried that, and it worked, but the display only moved a tiny bit... Would I put a pick in to hold the display?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 92
