The D-Link DNS-323 is a two-bay network storage enclosure that is designed as a comprehensive solution for network storage.
4 Questions View all
Need Help with DNS-323
Hi, I have swapped out the two 2TB HDD and it only seems the left side will connect (map). The front blue indicator shows both drives but only one connects, the second one does from time to time, it has always been like this from day one, any suggestions?
Add a comment
1 Answer
Check how your raid access is set up.
It may be the config isn’t correct
Add a comment
Add your answer
tread72 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 355
