Error code - "Uc"?
Hi, my washing machine recently displayed the error code - Uc.
Its not in the product manual and I have no idea what to do. Any help please?
vextox, depends on what make and model your washer is. Maytag washers display the UC error when the machine is unable to spin the basket. It is the same as DC indicating the machine it is unable to spin, and they both point to the same two components as a possible failure. For the Maytag that could be a bad clutch or the sensor arm.
Hello !
I am solve problem with UC error . Fault is on washer PCB . You can chage it with new , or ??
I find that one of relay when was energized not have good conctact . It is relay which is marked with white
sign . Black wire come to that relay and when is energized curent pass to blue wire which go to washer door . I remove relay plastic with screwdriver and saw conctact of relay . With screwdriver push stabile conctact to be near to other conctact . With that move i make beter contact on relay . I read on instrument 220 V betwen blue wire on relay marked blue and blue wire onrelay marked white . After that I close relay plastic with glue . Washer work and no problem .
all best regards from Zlatko
can you explain more pleas i have same problem in my washing
I dont understand. My machine brand is samsung and when i tried again it still show ‘UC’ . So im not sure what to do. Please help
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 16,217
