A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
55 Questions View all
Kindle Paperwhite Repair code comes on after screen replacement
Can anyone help me with a problem. I replaced my kindle paperwhite screen and now I get the screen saying repair needed. Battery invalid:-22. I am glad the screen works.....
Help??
Score 1
Add a comment
Did you find any solution to this?
I have exactly the same problem. I assembled a paperwhite 2nd-gen screen with a paperwhite 1st-gen motherboard and get exactly the same error.
EDIT (typing mistake): it was a 2nd-gen motherboard and a 1st-gen screen
2 Comments:
Where did you find a screen of 2nd gen? I need to replace mine.
by
Oh sorry... I mistyped something. What I meant was i assembled a "paperwhite 1st-gen screen and a paperwhite 2nd-gen motherboard"
by
Add a comment
Received a 2nd-gen screen today, still getting repair-message.
5 Comments:
It's not good. Last week I bought this one http://www.ebay.com/itm/311350255136 (2nd gen screen to my 2nd gen motherboard) and I'm waiting to receive it. I hope not to get the same message because I don't know how to deal with it.
by
The message is "Battery invalid:-22.", correct? Did you try to disassemble and connect the battery again? Or a hard reset?
by
That's correct! Yes, I tried both. My current approach is to try it via serial connection. Maybe it's just a software-issue that could be fixed that way. Has your screen arrived yet?
by
Hello, men! So, what with your Kindle now? A you repair it? I have a same problem now.
by
by
Add a comment
Any solutions? I have same problem
Add a comment
I came across a russian site http://kindle.zzweb.ru/paperwhite/repair.... Basicly it sates this:
  1. Connect the Kindle Paperwhite to a computer USB-cable.
  2. Create an empty file in the root directory DO_FACTORY_RESTORE.
  3. Safely disconnect the reader from your computer.
  4. Reboot your device by holding the power button.
I did this and my kindle paperwhite did a factory reset and I was able to use it again. I had previously tried to format the drive and place a firmware update on the drive so I do not know if this will remove your books. Please try and back up your books if you can before you do this.
Hope this helps others.
Add a comment
Add your answer
sdinovitz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 2,469
