Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
150 Questions View all
Black and white lines across screen
My son dropped his iPad, which resulted in streaks all over the screen. Whacked it a few times as many have described here, the issue changed to only multi color blocks across the screen. It has now gotten to the point where there are only black and white lines across the screen and when I move my finger across the screen, dozens of finer black and white lines show up.
I have opened the iPad up and reseated the cables but the problem still persists.
Will the screen run without the digitizer in place? Can a defective digitizer cause this issue or would that be the LCD screen that needs to be replaced?
I ran an iOS update without any issues just now and the computer detects it as well without problems so I'm hoping the board is fine and I'll have to either replace the LCD or digitizer. Thoughts?
Score 1
Add a comment
1 Answer
Sounds like the lcd to me, the digitizer shouldn't cause lines in the screen.
1 Comment:
Aside from the LCD, will a faulty logic board cause the lines? After reassembly, the screen has colors in the lines again instead of just being black and white. Doesn't a successful iOS update rule a faulty logic board out?
by
Add a comment
Add your answer
Guschtl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 451
