The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46 Questions View all
How can I repair a wobbly analog stick?
The problem with my GameCube Controller analog stick appears to come from the motherboard itself.
At default position, the analog stick will move with tilt, and between those points at which it will tilt (i.e. if I tilt it up and it goes to X, and if I tilt it up and it goes to Y, between X and Y), when I am moving the analog stick, it slides far too easily.
I have located the problem on the circuit board (the stick-like thing that connects to the analog stick isn't glued onto the two boundaries put in within the white ring inside the sensor), but I don't know how to fix it without heavy risk of either breaking the controller (spilling hot glue onto wire) or rendering the analog stick useless (gluing the stick-like thing to the white ring).
How do I fix this?
Add a comment
1 Answer
I hate giving this answer, but a quick search of eBay shows that you can purchase a used working GameCube Controller starting at $6.38 shipped. I think that you would be better off getting a good used controller to replace your defective one. Honestly that is the best answer in my opinion.
John.
1 Comment:
And don't throw the non-working controller away if you do this-- sell it for cheap on Ebay or something to someone who can fix it, or if it's beyond repair, use for parts.
by
Add a comment
Add your answer
Zach Myers will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 47
All Time: 4,454
