Laptop screen very dim
Can barely make out images on laptop screen. Screen displays fine on external monitor. Thought it was the inverter board, so replaced, but same problem. Replaced logic board, still same problem. Any ideas? Brightness is whole way up.
Score 1
Add a comment
Chosen Solution
If I read you correctly you have replaced the inverter board and the logic board. The unit functions well with an external monitor. It would seem that leaves only the cable from the logic board to the inverter board or the LCD itself. I would try the cable as the lower cost part first. I am including the link for replacing the LCD but hope you won't need it. Good luck Ralph
PowerBook G4 Aluminum 12" 1-1.5 GHz Display Replacement
Score 2
1 Comment:
Add a comment
Most Helpful Answer
There's only the LCD & the Display Data Cable (LVDS) left and it doesn't sound like the cable.
Score 2
1 Comment:
I've got to learn to type faster. + Ralph
by
Add a comment
Add your answer
sdheck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,352
