1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
374 Questions View all
Isolating MacBook no power issue
Hi Everyone,
I have a 13" Mid 2012 Macbook Air that has stopped turning on.
I have tried multiple known good chargers - no light on any of them.
SMC Reset, unplug battery + power button all did not help.
No activity at all upon powering on. There are NO battery status indicators on this model to tell if battery is charged at all..
I assume that it is either the logic board or the I/O..
Is there a way to isolate this between a faulty logicboard and a faulty I/O Board?
I understand the $90 I/O Board would be a better place to start then the $400 logic board - but was curious if there was anything I could do to test for sure which is the failed component. Is there a way to send power to logic board bypassing the I/O Board? It's likely the battery is completely discharged so I don't think shorting the pads did not seem to work, due to I'm guessing no power in the system.
Thanks in advance
Score 2
Add a comment
1 Answer
Chosen Solution
There's really no way to tell until you drop in a new battery, get it started and run diagnostics.
Score 1
2 Comments:
Is there no way to power the mainboard directly?
by
I have a similar problem with my MacBook Air Mid 2013. Was working great the previous evening, then the next morning it would not power on. Plugged in with a new power cord - nothing. Replaced the I/O board, nothing.
Does this narrow it down to the logic board?
by
Add a comment
Add your answer
mikejensen13 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 533
