Replacement of hard drive with larger capacity cause issues?
Hello! I need to replace the HD in my iBook G4 12" 1.2GHz 30GB HD. I'm looking at buying your IF107-069-1 (320 GB 5400 RPM Western Digital ATA Hard Drive). If I replace my HD with a larger capacity HD will I loose any functionality?
Also, is there a larger or faster RPM HD for sale for this model? The reason I ask is because I once tried to replace the HD in a G3 iMac with a non-approved HD and that iMac would no longer go to sleep.
Score 2
2 Comments
Colleen, thank you for the prompt response!
by
If Colleen's answer helped you, you should accept the answer. If you're still not sure of a resolution, at least vote her post up.
by
Add a comment
1 Answer
Chosen Solution
I haven't had any problems with replacing these hard drives. Anything ifixit sells for your model should work just fine.
I think size is more important than speed. I stuck a 7200rpm drive in my MacBook but haven't really noticed any difference.
Score 5
2 Comments:
Just had 10.4 installed on my iBook with the 320 GB Western Digital hard drive I bought from iFixit.com. The WD works well and the computer goes to sleep as usual. Thanks for your help Colleen!
by
I agree with Colleen. Especially with a G4, hard drive speed is not going to be the bottleneck, as long as you are at 5400RPM or faster.
by
Add a comment
Add your answer
Stafford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,585
