The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Questions View all
MacBook Air boots to strange screen - What should I do?
  • Problem :
I left the Macbook to be idle for a while, its keyboard and touchpad is not responsible. Shut Down and start 3 times (use power button), the Macbook go to strange start up screen.
  • Current situation :
I tried all boot options , but it's still not work. The only thing I can do :
+ Turn off (Use power button).
+ Turn on (Use power button), it starts and go to the screen.
  • Detail boot progess :
1. Press and release power button
2. Apple logo and progress bar displays (As soon as I press power button from turn-off state).
3. The progress bar runs and the screen shows up with the pointer in top-left conner of its screen.
4. I can't do any thing except turning off the Macbook.
Also, the video show full start-up progress :
http://www.youtube.com/watch?v=xRy8QgdBj...
  • Below is the Macbook spec :
1.7GHz Intel Core i7 Dual-Core (Haswell)
8GB of 1600 MHz LPDDR3 RAM
128GB Flash Storage
Integrated Intel HD Graphics 5000
11.6" LED-Backlit Glossy Display
1366 x 768 Native Resolution
802.11ac Wi-Fi, Bluetooth 4.0
Dual USB 3.0 Ports, One Thunderbolt Port
720p FaceTime HD Camera
Includes Mac OS X 10.10 or OS X 10.9
Update
The Macbook is silent as I minimized sound volume before it's failed to boot. Looking forward to seeing any advices.
Thanks,
Vinh-
Score 1
5 Comments
Did this happen following some incident such as hard drop or liquid spill? This thing isn't seeing the keyboard..
by
See what happens if you hook up an external keyboard.
by
Same screens - I was using Magic Mouse and Keyboard in the office - but now I’m travelling without Magic Mouse or Magic Keyboard - just discovered the issue and I’m stuck! Is there any way I can reboot without them - please help - thanks in advance friends
by
I’m having this exact same problem after opening my Mac for the first time a year after it having water damage (for me the picture of the mouse is the same and instead of having the one of the keyboard it’s a picture of the side of the Mac) and while the pictures were showing it died and it’s not turning on again can anyone help me please because I know nothing on this subject.
by
I'm having this same problem with my 2019 Macbook Pro. It continuously asks for the Magic mouse and keyboard which is in my home office and I can't get the internal keyboard and trackpad to work to log in to my computer. Apple Support is also having trouble finding a solution.
by
Add a comment
Chosen Solution
Clearly the system can't see either the internal keyboard or trackpad. Which is why it's asking for both an external keyboard & mouse.
For now you'll need to connect an external keyboard & mouse (USB or Bluetooth) to get things going.
But why is it asking? That would imply the system got wet damaging the keyboard & trackpad or someone forgot to connect them back up internally (or damaged the connector or cable).
Score 4
Add a comment
I had this problem with another laptop. I plugged in an USB mouse and keyboard and restarted. The computer then gave me a choice to change my password or it let me choose the option that it wouldn’t let me log in. When I chose that option, it turned off the firevault and let me log in.
Add a comment
Hi any one tell why is comes on my MacBook Pro this image?
Update (12/13/19)
Hi any one tell me about this issue plz
1 Comment:
This is any older system likely 2011 or older. As this MacBook Air system doesn’t offer FireWire connectivity.
The system is looking for a drive, the icons are Thunderbolt and FireWire.
Sounds like the internal drive is damaged or missing.
by
Add a comment
Hi I had this issue with a 2015 Macbook pro 13 inch.
I opened it up and unplugged the battery, screen and trackpad ribbon connectors and then reconnected and it booted fine.
Add a comment
Hi, I keep pressing power button and command r but this mouse/ keyboard keep appearing. i want to reformat my comp do you have any idea?
1 Comment:
This happened to me not long after a liquid spill & freezing temperatures around the same time . Still trying to fix .
by
Add a comment
Can it still be fix il spilt mines with rice while eating and now im facing the same problem. Can it be fix without going to the service center
1 Comment:
You’ll need to clean out the rice and the broth as both will damage things if left inside.
by
Add a comment
Add your answer
vinh Vo will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 59
All Time: 44,661
