Repair and disassembly guides for the Huawei Ascend G6.
23 Questions View all
My phone wont charge
i recently discovered that my phone will not charge after i had returned from a friends house and the battery had died so i put the phone on the charger but all that happened was a small red light flashed once above the screen and nothing else happened. this happened every time i placed the charger in the phone. i have already tried using other chargers and that didnt work so i tried cleaning out the charging port and that also didnt make any difference. any help is much appreciated.
Score 8
1 Comment:
I just have the same exact problem and don't know what to do.
by
Add a comment
You'd have to change the motherboard to get that fixed. They usually cost about 70$ CAD to fix. Easy enough if you have the parts and the tools. Best of luck!
1 Comment:
may I ask, what makes you say that?
by
Add a comment
Si lo conectais a un pc mediante el cable de mini USB y el pc no lo reconoce tal vez tengais el conector inutilizado por alguna cuestion como este dañado o desoldado en algunos casos....
Add a comment
Add your answer
gerard holden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,960
