The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Questions View all
Why is my controller over heating, and not vibrating?
I found that after a month or so after buying the Call of Duty Xbox One. That the controller that it came with began to over heat and not vibrate. I also have found that the plug and play rechargeable battery that I use loses power very fast as well in this controller, but does not in the controller it came with. I have tried doing a firm ware update with it, and followed all of Microsoft's troubleshooting tips but nothing has helped. It says to send it back to them but I would like to fix the problem on my own.
Score 1
Add a comment
The wire from the vibrating motor probably came loose and is now touching other things in the controller causing the problem.
Add a comment
If your Xbox One Wireless Controller no longer vibrates when it’s supposed to, see the Xbox One Wireless Controller Won’t Vibrate problem page for possible problems and solutions.
Add a comment
Add your answer
siebener will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,071
