An Android smartphone by Samsung for the Asian market, known by many model numbers, released December 2014. Includes models SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W.
118 Questions View all
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
Score 21
28 Comments
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
by
That was a fantastic clue. works perfect!. Thank You Dude.
by
Wow that really helped me thank you very much
by
worked perfectly. thanks much!!!
by
Amazing advice! Nothing else worked but this did. Thank you :)
by
Show 23 more comments
Add a comment
Chosen Solution
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
Score 33
21 Comments:
Dat was really helpful. ..thanks!
by
its working thank you so much
by
its good idea..... thank u .....
by
good job...... i really like u......
by
it's work... thanks
by
Show 16 more comments
Add a comment
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
Score 3
2 Comments:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
by
Many, many thanks
by
Add a comment
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
Add a comment
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
1 Comment:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
by
Add a comment
Add your answer
Billy495 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 59,960
