The Epson WorkForce 645 is an all-in-one office color inkjet printer. Model: C11CB86201.
42 Questions View all
changed cartridge and now the printer is stuck on Cleaning Head
Change the cartridge but it won't print. IT keeps saying "cleaning head and I'm losing inks. I have lost 3 cartridge already, it just keeps draining all my ink and not printing.
Score 1
Add a comment
robr389@gmail.com
This is a common problem with this printer. The inkjets have the tendency to clog, especially if you are not using the printer often, or even if you are using it often, but only printing black. Normally the "Head Cleaning" maintenance routine will clear the jet head. However, the cleaning process always takes an unacceptable amount of ink and in your case (and mine at this moment) the cleaning routine makes no improvement. Regardless of the routines failure, it still uses more ink than any normal person can afford. I am researching the issue and will post any helpful info I can find.
Add a comment
Here is a guide with several methods to clean your Epson printer in ascending order of ruthlessness :)
http://www.ebay.co.uk/gds/How-to-unblock...
Add a comment
Add your answer
Sandra Ladson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,159
