The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
50 Questions View all
need replacement fan, behind modem, ethernet etc
I need a new fan, but I don't know the part number (or where I can get one) - or what this particular fan is called so I can order a new one? I looked at the teardown and by removing the two screws next to the ethernet, usb, firewire etc., ports on the back I can remove and replace my now very noisy fan which is on the other side - it just started getting noisy a week ago. Thank you! jon
Add a comment
Chosen Solution
You're probably talking about fan part number 922-3295
Here's a parts teardown: http://ep.yimg.com/ca/I/lovemacs_2113_43...
Here's links to the part:
http://www.allmac.com/shop/product_info....
http://www.mac-pro.com/s.nl/it.A/id.2239...
Score 2
1 Comment:
Add a comment
hmm, actually I don't think that's it - this chart is really cool, but it's showing an earlier G4, not the Quicksilver - and the fan doesn't look correct. Mine has a chunky black case. But thanks for the effort. jon
2 Comments:
there were two versions of the 733. Both used the same fan. See if this looks right: http://ep.yimg.com/ca/I/lovemacs_2114_10...
by
I ended up ordering cpu fan #2410ML-04W-B47 off of ebay, It looks to be the right fan and it was only $10. Thanks - jon
by
Add a comment
Add your answer
jon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 980
