Released June 2014, identified by model 635.
55 Questions View all
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
Score 4
Add a comment
Most Helpful Answer
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
Score 1
1 Comment:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
by
Add a comment
lumia 635 power baton bord not warking
Add a comment
Add your answer
gobstopper2 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,021
