Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
102 Questions View all
iPad display turns off by itself
While I'm using it, the display turns off. Looks like the display backlight is perhaps still on (in dim light I can see it as very dark grey). I can get Siri to shut it down (don't need to see the display for that.) Sometimes I can get it to go back on just by waiting a few minutes, sometimes I can get it to come back on if I use the home button and on/off switch together and get it to restart. Took it to the Apple Store "Genius" Bar and we did a complete restore. Didn't make any difference to its behaviour.
Last couple of weeks it's been more difficult to get it to come back on, and this week it was off for a few days. Tonight I managed to restart it and it came back on, so I've backed up again ready for more serious measures.
Thinking it might be the connection to the display, display data cable ???
Score 1
1 Comment
Another clue: Occasionally this happened when I left it in a place where it probably got rather hot.
by
Add a comment
1 Answer
Most Helpful Answer
If you can still see the image in the background in dim light the inverter may be the problem. If it was me I would probably replace the LCD. You may be right in thinking that the connection may be loose. If it's not the cable then your LCD is slowly dying and it will continue to get worse. Your apple genius isn't much of a genius if all he did was a reinstall.
Score 1
2 Comments:
Thanks for your quick response.
I don't see any image in dim light, just a very dark homogenius glow. I see there is a repair guide for a 2nd gen iPad but not for a 3rd. Would it be the same? I think the 3rd gen was the first gen with Retina display.
by
I can't say off the top of my head that it is the same as the 2nd gen but I know it is the same as the 4th gen because they are the same LCD. Try looking for that one.
by
Add a comment
Add your answer
cjberry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 474
