Repair and disassembly guides for a large selection of Canon digital and film cameras.
1825 Questions View all
trouble massage like Ubdate Firmware *Bios Mode*
my printer write a massage when i want to print an on the printer the massage says
Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420
Score 51
2 Comments
Have u solved it? I have the same problem. Thanks
by
plz help i need a help
by
Add a comment
Most Helpful Answer
ok then how can I solve this problem plse help how can I do " Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420"
Score 20
2 Comments:
by
canon ir 2420 update firmware bios mode
by
Add a comment
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Score 6
Add a comment
Score 4
Add a comment
this is all problem solution
Score 3
1 Comment:
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
by
Add a comment
hello i have machine canon ir 2420 , error message update firmware , i am change board usb , fix problem
Score 2
1 Comment:
That will work for sure! BUT will cost you a fortune! And yeah - that is much easier!
by
Add a comment
https://www.canon.fr/for_work/mobile-sca...
Score 1
Add a comment
Here is what you can do. That helped me once.
You need to get to mainboard and find there flash memory. In my case it was chip - 25Q64BVFIG. It contains firmware for that machine.
Then - need to desolder it, reprogram using programmer with support of that type of schemes and solder it to mainboard again.
Downbelow will be a link for dump to download (must mind you - that Canon iR-2420 was in Russia and I'm not sure about differences between US/Canada and European firmwares. Just to let you know that beforehand - that there might be some problems to show up. But I suppose - since machine will finish loading inner software and comes to ready state - you can just figure it out by playing with local/country settings). These are photos before and after (connector melts a little)
- About dump - it's ready to use with your programmer - it's been taken from newly installed machine (not by me - but from guys from similar Russian tech forum). DUMP for reflash memory chip
- About programmer - mine is - TL866A - pretty simple and cheap
Good luck! Hope that will works for you!
Score 1
1 Comment:
Here is link to forum Copytechnet - where I originally posted this recommendation
http://www.copytechnet.com/forums/canon/...
by
Add a comment
yep! what if i swap the chip with the one from 2318 ? will it work?
Score 1
1 Comment:
Not 100% sure, but suppose yeah, that might work for you.
by
Add a comment
ما حال مشكلة هدا راسالة الة سحب
canon 2420
Message please wait
Score 1
Add a comment
this is also my problem pleas give me solution
Add a comment
what would be the problem of this and what should i do ?
1 Comment:
what would the problem of this and what should i do
by
Add a comment
Boa tarde a equipe da CANON, eu tenho uma maquina fotocopiadora canon 2420, ela tinha problema de fonte e ja foi resolvido, so que nao esta a fazer copia, aparece na tela a seguinte mensagem: Update Firmware * Bios Mode* 2010/10/28 VO.10W STARDR 5N
1 Comment:
Como solucionar esse problema?
by
Add a comment
Please if any body knows the solution on how to fix this problem of (* bios mode * firm ware update ) on IR2420 Canon .
Please E mail me on vifeanacho@gmail.com
Add a comment
i need ir 2420 firmware
help me
Add a comment
https://cloud.mail.ru/public/E3FN/g9Ry4q...
Add a comment
i need ir 2422 firmware
Add a comment
Add your answer
wendosen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 64
All Time: 9,049
