The Dell Inspiron 15-7537 is a 15.6" touchscreen laptop with an i5 core processor.
22 Questions View all
Trouble replacing Dell Inspiron 15 7537 display hinge
Hi, my name is vikrant. I have dell inspiron 15 7537 laptop.
Accidentally that laptops one side display hing is broken. I called
dell customer support for that but they said display and hing are
fused together so if you have to change hing you have to buy all the
display assembly. After that I searched on Internet for solution but
nothing helped me out. So if anyone knows how to change the display hing of dell inspiron 15 7537 please help me out.
Score 6
2 Comments
Hey Vikrant! How much money were you charged in the end?
by
probably this is too late to answer, I think I didn't got any notification for this question I posted 5-6 years ago, anyway, back to answer your question.
I did not repair it at authorized service center, I took apart the laptop myself and glued down the broken part to the aluminum chassis with the help of industrial glue.
After use of another 2-3months another side hinge was broken with exact same issue, so I repeated the previous step and my issue was resolved till date there is no other issue with hinges.
by
Add a comment
Chosen Solution
What they said is true. I had the same problem. The hinge will be screwed/fused to the aluminium laptop lid. When the display hinge breaks, it is actually the screw thread/molding in the laptop lid that usually breaks, check if this is the case. This is your worst case scenario.
So, the only way to replace the aluminium part of the lid is by taking it from another laptop. There will be ebay listings (mostly in ebay.com) that sell scrap parts from broken/second hand laptops. That is your only option for a cheap DIY fix.
The other option is to go the official route. Hope your's isn't a 1080p display. Will set you back by quite a lot of money, as they only had 1080p models for a little while in 2014. And for some reason dell doesn't provide 1080p panels in midrange models in India.
I have Dell accidental damage protection till 2017. When I informed them that the right side hinge broke on regular usage, they said that the warranty will not cover it, seeing as how it is not accidental damage but normal wear. But after some haggling with the call center employee and her supervisor, finally they agreed to replace the whole thing free of cost.
This is not an isolated issues either, happens all the time with Dell laptops. That is why I always extend warranty for Dells, totally worth it. For me the replacement parts cost 18K, I bought the warranty for 7K.
Score 5
2 Comments:
HI I amIn USA I have Dell Inspiron 15 7000 series. For me it looks like the Aluminim Casing for display is broken. Laptop is fully functioning but I cannot close it as the Display and casing from one side are separated and I cannot make the hing function. As I said I am in USA, so it means I do not get the casing from Dell and have to replace the Display????? I bought it in April 2014!
Thanks for help
by
@reza sabet so, your hinge is broken and it splits from the aluminium lid when you try to fold the display...
well if you are in the US, you can get the "Back Cover with Hinges" from Dell. they's ship something like this...
http://www.ebay.com/sch/i.html?_from=R40...
Should cost you ~ $130 if it is from Dell.
Hope everything works out.
by
Add a comment
For those who have this problem I had a unit brought in with the same issue.  Terrible design and cheap plastic makes for a broken hinge (shame on Dell).  Parts are few to come by and just plain too expensive (even if I did get the parts and spent the money this is just going to happen again down the road).  I ended up cutting out the garbage plastic corner and redesigned it in cad and printed the part in ABS.  Problem solved!  For those who suffer on this issue I would be happy to print the part for a small fee plus some tips and tricks to get a good fit that I learned as I did this.
Score 3
3 Comments:
The plastic of my dell also broke where the right hinge attaches (the right one while using the pc). I live in europe, I think asking you to print a replacement and shipping here would be pretty expensive, but I do own a 3d printer now, I was wondering if you were willing to share your solution, or at least some insight and advices on how to design the piece from scratch.
by
Hard to say what shipping would be but some how China can ship for a penny's on the dollar. I could probably post what I did on Thingiverse. However the hinge I repaired was the left side. From what I recall I don't think they are the same design. I suppose when the right hinge breaks i'll get it back to design that side. :) ABS was strong enough for this to work well. You would need to salvage the embedded screw mounts off the broken one for the printed part. The printed part was just right for the mounts to grip and I used glue to keep it in place. I then used a small amount of Acetone to "weld" the left side of the part that I cut out and then a little glue after that. The main reason for cutting plastic up the left side of the screen was to give my part more strength and leverage instead of right at the hinge (used a dremel for that). In my case there were a few dents that I ended up sanding the part just a little for a perfect fit. So far 6+mo working great with college student abuse.
by
Well, if you happen to put it on thingiverse let me know, I might be able to adapt it enough from there :) it's just a shame how dell has designed this laptop...
by
Add a comment
This tutorial shows how to replace the hinges. It doesn't look like they are fused to the lid. BUt it is rather involved to get to them: https://www.parts-people.com/blog/2016/0...
Score 1
1 Comment:
That video is real helpful - but that reiterates my point, the hinge is screwed into the plastic platform that is fused to the aluminium lid as shown here
https://youtu.be/-RpoPytS_qU?t=255
The plastic threads of the two flathead screws in the top of the hinge disintegrate and the glass splits from the backplate.
by
Add a comment
You need to buy the front cover with the cheap black plastic pieces that run from top to bottom for the hinges to screw into. It is a manufacturing defect as far as I could see. I bought a used cover with a capacitive touch screen already attached. You never know if the touch screen and related board are ok. I paid $50 on Ebay and it worked well. It was not too difficult to replace but the real problem is it is happening again on my left hinge. Dell need to recall the covers with the cheap black plastic strips and solder or weld nuts on the covers for hinges to screw into.
Score 1
Add a comment
DELL Inspiron 17 7537 - After two decades of being LOYAL customers (1998), The LAST PC we will ever buy from DELL... $1,500 for a Windows 8 driven, beautiful 1080P Touch Screen accompanied by a !#^& poor NIC, a defective illuminated keyboard and now these "Hinges" wow, were they giving away awards for the worst possible engineering one could accomplish.
Thank you all for posting here and
Thank you Vikrant Chaudhari, NOT while diligently Googling, no…I actually found this article five years later in a link here:
https://www.dell.com/community/Laptops-G...
Score 1
Add a comment
Add your answer
Vikrant Chaudhari will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 8,904
