Released 1990 as a successor to the Apple Extended Keyboard. Models M0312 and M3501 were produced, using either the legendary ALPS tactile switches, or Mitsumi standard mechanical linear switches.
command shortcuts not working
I wiped down my keyboard with one of those lysol wet wipes and now my command key won't work ... for example: I'm in InDesign and my command C just types a c and doesn't copy. I have the extended keyboard plugged into my MacBook Pro. I wiped down both keyboards. Now I can't figure out how to restore my command shortcuts or if I got the inside of my keyboard wet. But all the keys work as a typewriter, just not the commands. I'm thinking that I somehow locked the command out or something as I rubbed over all the keys, but have no idea. Anybody?
Add a comment
1 Answer
Being able to reroute some keys may help with your trouble shooting or give you a temporary solution. For instance I have rerouted my CAPS lock key to ESC because it is more useful.
This app does the trick:
https://pqrs.org/osx/karabiner/seil.html...
Add a comment
Add your answer
jpgrahamjazz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 339
