Very Frequent White Screen Of Death
Everytime I turn it on to use it, a white screen of death pops up. I reboot it by holding down the slide switch and after 3-5 reboots it stops showing the white screen.
spotlightsrule this sounds like an issue with either your firmware or with your LCD. Check on hereabout the reset of your Fuze. If that does not work you do want to disassemble it carefully by using this guide Disassembling SanDisk Sansa Fuze. From there check the LCD connector for any corrosion, bend pins etc. You can try and reseat the LCD cable. If that should not resolve it I would consider replacing the LCD.
Did you try opening it up and checking the soldering points to make sure that there all in tact? That will most likely be your problem. I have a few more ideas of what the problem is if that was not it.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 2,031
1 Comment
Turn it off and then turn it on while holding DOWN BOTH BUTTON ON THE FACE AND THEPOWER BUTTON ON THE SIDE UNTILIT TURNS ON. It worked for me.
sonofkerry2
by Pat
