The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
31 Questions View all
Got it wet everything works just black screen?
Okay so my mum accidently dropped her phone down the toilet. She is technologically impaired so she's been sitting around thinking it's completely dead for us just under a year and living of a brick. Well Ive Tried To turn it on and it lit up made sound vibrated then the light went and I thought all hope was lost but the vibrations continued as did the noise.. It charged up and the screen occasionally flashed. Anyone have any clue as to fix it?
Score 2
Add a comment
1 Answer
Chosen Solution
Aelrahc, be nice to your mum. You should try and teach her how to fix things instead of calling her "technologically impaired", not nice. Anyhow, may be there is a trick that you might want to teach her.
STOP continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. Remove the battery.
The very first step I would take is to disassemble your phone. Use this guide to disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Use a soft brush and clean it very, very thouroughly with sterile water. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. the best of course would be to get it professionally cleaned with an ultrasonic cleaner. Do not forget to replace the battery after you cleaned it properly. This is a must and not an option. It will fail if you do not take care of it now. Keep in mind that water damage is the hardest to troubleshoot and to repair. In your case with the "screen occasionally flashed" it is possible that you will have to replace the display to get it properly working again. Hope this helps, good luck.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Samsung Galaxy Ace Logic Board Image
Guide
Disassembling Samsung Galaxy Ace Logic Board
Difficulty:
Moderate
10 - 15 minutes
Score 2
Add a comment
Add your answer
Aelrahc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,075
