A 65" rear projection TV by Mitsubishi.
7 Questions View all
cap values on DM power board
I was getting ready to perform repair for blinking green light on my old Mitsubishi WS-65511. Pulled the DM power board and noticed the values on the caps are 1000uF 25V. I had read to buy replacement caps that are 1000uF 16V so that's what I bought. Any advice as to what to do? I'm confused. Thanks in advance.
Score 1
Add a comment
Chosen Solution
jrmcdown, I just double checked the schematic and the 1000uF are all 16V. May be these have been changed once before. You are okay with using the 16V per schematic.
Score 1
1 Comment:
Thanks soldered in the new caps. Unfortunately must be something else. have constant blinking green light now. Thanks for answering my question though. I think the 25V were installed by TV repairman from previous problem.
by
Add a comment
Generally, you are safe if you use over-rated caps. So you could replace 16v with 25v or 50v caps, but you wouldn't want to use 16v caps if 25v were required. - I've heard the 16v caps spec'ed by Mitsubishi are under-rated, so generally when being replaced it's a good idea to use 25v or greater.
Add a comment
Add your answer
jrmcdown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 357
