Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
158 Questions View all
no signal from computer to moniter
Their is no signal from my Asus essentio to the monitor . The monitor is working fine as I have cctv cameras attach to monitor and it is displaying them fine, I have also checked cables which are all fine. This has lead me to believe that this could be the graphics card . I have taken a look inside the computer and I can t see the normal set up with a removable graphics card attached to the vga port so I am now wondering if the whole motherboard needs replacing. Thanks
Score 3
Add a comment
Chosen Solution
haguehags ,
Hope This answer will hep you to get idea to fix you PC
Score 2
1 Comment:
this isnt hel[ full
by
Add a comment
Greetings,
Check the monitor for which type of input signal it is currently set for.
- there should be a choice within the set-up options for Dvi, HDMI, Display port or whichever cable type the Pc is connected to the monitor with.
- insure that the cctv cameras are not set as the default source.
Hope this helps in attaining a signal.
Score 1
Add a comment
asus pentium3 power ok ram clean ok showing signal ditected
Score 1
Add a comment
Add your answer
haguehags will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 4,343
