unable to print 51
Brother MFC-665cw
what does unable to print 51 means
Brother MFC-665cw
SOLVED
It worked!!! Thank you!
Machine off
- Switch on the machine while holding down the "Menu" button, until all the leds are flashing on/off: it's the "maintenance" mode.
- Press 80
- Press the "Mono start" button several times until you see "purge: xxxx"
- Press "2783" in order to reset the purge counter. You will see: "purge:0000"
- Press the "Stop" button.
- Press "99" to exit the maintenance mode.
This may or may not work but it's worth a shot.
This worked for me, thanks!!
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 46
All Time: 18,273
1 Comment
Thanks...unfortunately, the dinosaur was not able to be fixed. Tried all suggestions and finally took it to a professional and they told me it wasn't worth the cost to try and repair.
by pretticute
