How do I get my videos from sanyo
how do i get my videos from sanyo
Usually cameras have a slot where you open it up and remove the SD Card, where all photos and videos are stored. Some require you to push in and it will then eject.
Then you would connect the SD card to a PC either directly (Some have card slots) or use a USB to SD Card adapter.
Usually you can get them on a computer if you use a cord that has a "B" on one end and regular usb connection on the other. The computer will pick up that the camera is attached and will install drivers (depending on type of computer) to give you access to the camera's internal memory. If you have a card installed, you can remove that card and insert it to the computer using a card reader unless the computer has one installed on it.
From there you should be able to just click on the cards folder and get your pics.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 294
1 Comment
Dsean Henry Sanyo what? What have you tried? what computer do you have? What software are you using?
by oldturkey03
