Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
How to check how good battery is with only phone and multimeter?
Hi guys,
I have a bunch of batteries and few working 3GSs. Recently I've been told you could test battery approximate state by checking amperage it takes during charging.
So now I have multimeter and if it is true I need some info on that and maybe points to put probes for checking that mAmps since I don't want to cut an Usb cord for that)
Add a comment
1 Answer
Chosen Solution
I don't know off hand.. How much mAh a 3GS battery should have.. Plus you're going to want to check them, once they have a full charge.. Lemme check..
Ok so it is 3.7 V and 1219 mAh
Score 4
Add a comment
Add your answer
iskra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 320
