The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Why is my replacement screen not sticking properly?
I ordered and replaced my busted ipad 3 glass using the instructions i obtained from ifixit. The instructions were very useful and installation was a breeze. I cleaned all the surfaces that the screen attaches to so the tape would adhere better using some light solvent being careful not to damage any internal components. For the first couple days after the repair all was well. The screen however keeps popping up along the bottom edges and I can not seem to keep it from coming up. I tried using some heat where the tape is and placed some weight on the bottom edge but the issue still exists. Please help. Thank you.
Score 1
2 Comments
Make sure it's not the digitizer flex cable pushing the screen upwards. Is it the bottom left corner?
by
Same situation with my first fix and the digitized flex cable seems to be the culprit. How can this be solved?
by
Add a comment
Most Helpful Answer
You will need to buy Red Tape. If it came with the black tape or 3M tape is useless i fix more than 10,000 ipad screens and those tapes are not the best the Red Tape i guarentee you you wont have that screen lifting problem .
Score 1
5 Comments:
Where can i obtain it from? Will i need to remove the entire panel and re tape the whole thing?
by
You Can Get it on Ebay and Amazon, Yes you will need to re-tape everything or you can just tape the area is just lifting.
by
I am having the same issue, with the glass not staying securely attached to the iPad. I went to amazon.com and typed in "red tape for iPad screen repairs" and 6 digitizer replacement screens turned up, showing the red on the back of the digitizer glass, BUT it only seems to come with the WHITE front border trim, and not the black. Is the tape itself sold separately?
by
Holy cow , that is an extraordinarily thin tape.
I watched this on youtube. Is this the gel like red tape you're referring to?
www.youtube.com/watch?v=Hy81hhvfX-s
by
Add a comment
some times the adhesive needs some heat to activate properly take and clamp it in place and see how that works
Add a comment
Add your answer
stiman82 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,653
