Why are my LED lights dim?
I have a string of multi-functional LED lights (can be white,colored or cycle from white to colored) which have been in place for 7 days. A section of the string is dimmed. I checked each bulb with a bulb tester and all light brightly, This string is in the center of a 7 string run of lights and all the rest of the lights are brightly lit. How do I troubleshoot this issue?
Score 1
1 Comment:
Hi,
Can you swap the string with another section in the run? If the fault goes with the string check the end connections. If not check connections either side.
by
Add a comment
1 Answer
Well when your LED lights dim it must be a problem with the voltage, did you checked this?
Add a comment
Add your answer
Linda Baker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 12,460
