Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
102 Questions View all
Can the Samsung 850 EVO be used as an external hard drive
Would like to use the Samsung 850 EVO as an external hard drive. Is it possible and what cables would I need if it would work.
Update (11/27/2015)
Thank you. The information and the site are a great help!
Score 2
3 Comments
I bought an enclosure, however I cannot get it to pop up in the my computer folder. Do I have to install software/drivers for it? I dont understand how to make it show up in My PC
by
You need to run Disk Management. Available under "Administrative Tools".
by
Have you reformatted it using Disk Utility?
I have one in an external case, reformatted to HFS+ (used to be in a PC) and it runs fine.
As to what case (the cable goes to the case) it will work in any case that you can connect to your Mac, so Thunderbolt, Firewire or USB 3, even USB 2 but that would be pointless as it would make a very fast drive run very slow.
by
Add a comment
Chosen Solution
All you need is a external hard drive enclosure . This video guides you through the process its for a 3.5 hd but a 2.5 ssd is the same procedure .
https://www.youtube.com/watch?v=20Hpa-sh...
enclosures can be purchased on ebay or amazon . If you dont want an enclosure you can by sata to usb cables
Hope this helps
Score 6
1 Comment:
by
Add a comment
You may want to look at a dual interfaced enclosure like this one: OWC Mercury On-The-Go. Here you get the faster FireWire 800 which your system uses as well as USB 2.0/3.0 for use in a newer system.
Score 3
Add a comment
If the hard drive is not recognized when you plug it into your USB you need to go into your Device manager and initialize the SSD. The same way you would set up a brand new hard drive out of the box when you install it on your computer. It needs to be initialized before it is recognized or has the ability for use on your computer. You can also set it up as a storage bin in device manager. That is the way I always do it anyways, Or you can purchase a duel interface casing as mentioned in previous comment a while ago. It has been a while since this comment was posted, so I’m sure you figured it out by now.
Score 1
Add a comment
Be aware that the SSD may consume more current than most USB ports are capable of providing and that would explain why the disk is not seen by the computer, or in my case, why the disk disconnects when in heavy usage. My 850 SSD states 1.4A peak current. My USB ports can only provide 900mA. It seems now I need to find out an external closure with two USB 3.0 connections, or maybe get a 3.1/USB-C enclusure and upgrade my Mac. Sorry, not a solution, just more details on the possible issue.
Score 1
Add a comment
Add your answer
Jay MacDonald will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 36
All Time: 34,748
