Repair guides and support for vehicles manufactured by the Oldsmobile division of General Motors (GM).
41 Questions View all
replaced broken blower motor resistor block works worse now
2001 Oldsmobile Alero - my blower fan was only working on the highest 2 settings I replaced the resistor block and now it's only working on the highest setting does anyone know why this might have happened or what could b wrong?
Add a comment
Chosen Solution
When the resistor goes its usually on the high settings if more than one works its usually the switch on the control that needs replacing . If it was the resistor and it went as soon as you installed it you need to replace the motor. Hope this helps
Score 2
Add a comment
pizon if the replacement of the resistor made it worse, double check your work and, if everything checks out, replace it once more.
Add a comment
Add your answer
pizon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 202
