Will not boot windows
I cannot get the laptop to boot in normal windows or safe mode. In normal boot it stays at the windows logo and kinda pulses. In safe mode it gets to where it appears it is trying to boot with a horizontal line like it is loading. I've tried repair and have not been able to get into the hidden directory that has the factory back up. Suggestions?
Sailor
Add a comment
1 Answer
If you are not able to boot the computer in safe mode, then try performing startup repair and check if it helps.
ReferStartup Repair: frequently asked questions
Insert the Windows 7 installation disc and try to initiate ‘startup repair’ from Windows Recovery Console.
http://Windows.microsoft.com/en-US/Windo...
Hope this helps.
In case of any system problem, you first priority should be to make sure you have up-to-date backup copies of your computer.
Add a comment
Add your answer
sailor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 43
