The third iteration of the 10.1 inch Galaxy Tab tablet.
125 Questions View all
microphone does not work
I recently changed out the motherboard on my Galaxy Tab 3 10.1, now the microphone doesn't work. The lock tabs for the ribbons broke off, could this be a reason for it not working.....any help..please
Score 3
Add a comment
1 Answer
Chosen Solution
Hi,
Can you make the microphone work by putting a bit of pressure on the cable connector with the cable inserted? If so, you may be able to hold the cable in, in the correct position, with a few 'dobs' of neutral cure silicon sealant between the connector, cable and mainboard. You don't have to smother it, just enough for it to maintain connection and to stop it from moving. Make sure it works after applying the sealant, allowing a bit of time to set first. If it works allow as much time as you can, for the silicon to 'cure' (set or harden), overnight should be sufficient. Do not use 'superglue! If it doesn't hold the cable in position properly, you are stuck, literally. Also it may react with the 'plastics'. With neutral cure silicon sealant you have a bit of time to get things right and it is relatively easy to remove.
Hopefully this is of some help.
Score 2
1 Comment:
I tried this..but I could not tell if it was working. Would face the screen down hold the tape. turn it over to see if it was working and it was not...Not sure if it moved when I turned it over or not..
But thank you
by
Add a comment
Add your answer
biterbites will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 3,365
