Everything you need to repair your iPhone yourself with free repair guides, and quality replacement parts and tools! From the newest iPhone 17 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone.
Secret Code for Display Test
Hello there,
can anyone help me?? Dis Apple had a secret code like Samsung (*#0*#) ??
Score 8
1 Comment
No it doesn't, because it's a cheap made chinese brand with 60Hz display and 3200mAh and times are rough, we can't add a fast charger of ...drumroll 18 Watts ...because we are saving the planet..
Whilst soldering ram, ssd for the past 5 years...and making flimsy too short backlight cables in 400€+ laptop panels and butterfly keyboards that stick like butter.
Running the company as a beancounter gets you trillions!
Bless c.r.Apple! :)
by
Add a comment
Chosen Solution
Nope there is no secret code to test the display.
You can use an app to test the screen however.
Score 9
4 Comments:
Apple iphone secret code please
by
@ikhlaq there is no secret code!
by
yes their is
by
I have seen this code used. And it worked. *#21#
by
Add a comment
You can check your screen either the panel is replaced or not by comparing your iphone to another which you think is genuine.
Score 3
1 Comment:
How do I test my screen because it’s not working properly i11 pro max
by
Add a comment
Hello: No secret code. However, the link to the APP for a screen test is in the iTunes store. As of August 23rd, 2017 you have Version 4.0.
https://itunes.apple.com/us/app/touchscr...
You can test the pixels, touch, pinch, move, multi-touch on 6s and beyond.
Remember, aftermarket replacement screens DO NOT provide the moisture seals, response, and drop performance so please use Apple Care or a Certified replacement brand such as eVero. Your iPhone is worth it.
Enjoy, have fun.
Score 2
Add a comment
Apple uses a special factory firmware called SwitchBoard to perform factory calibrations. It is NOT possible to install it without factory or service center tools, so there is no code to stare test mode because it is likely never there on retail devices in the field.
Score 1
Add a comment
Apple iPhone secret codes
https://mobilespecs.net/phone/codes/Appl...
Score 1
Add a comment
Smartphones secret codes and other hidden functions
Add a comment
Add your answer
Selvan will be eternally grateful.
Past 24 Hours: 24
Past 7 Days: 183
Past 30 Days: 642
All Time: 269,992
