The iRobot Roomba 655 Pet Series vacuum manufactured in 2012. Costco exclusive.
29 Questions View all
Why is the battery light flashing on my roomba?
The battery light and the clean light are flashing the battery light is amber color and the clean light is green but they are both flashing and it does not appear to be charging.
Score 1
Add a comment
Chosen Solution
ajfaith1012, by your description it sounds like a problem with the battery charging. Either your battery is bad, the charger is bad, or the charging circuit inside your Roomba has failed. You could start with a new battery and after that try an external charger for Roomba batteries.
Score 3
4 Comments:
Does it take batteries Even though it's charging on outlet
by
Where's the batteries located on irumba
by
OK can't find it
by
Elena Chreene what model is your Roomba?
by
Add a comment
After trying the standard and much covered Power Reset buttons press (see Youtube.com) I still had an orange, flashing (slowly) battery icon. I did the reset three times and left it to charge overnight. Still no luck, so I unscrewed the bottom plate (how you access the battery) and installed an old but still working battery. My Roomba 655 then ran for 12 minutes, which is the length of the charge that battery holds. I have a replacement battery in there now and it WORKS!
3 Comments:
It still does not work it comes up with a error number 0 0 7
by
Should I order a new battery charger for it
by
Should I go ahead and order a battery charger for my 665 roboma
by
Add a comment
Add your answer
ajfaith1012 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 99
All Time: 27,644
